will not boot goes straight to bios with HDD/SSD not installed
was working now wont boot to windows found no 12v to HDD all other voltages present 3.3/5/19 checked on board fuses cannot see any componants that look faulty i cannot find a mother board voltage test point schematic , i have all test/repair tools HELP !
좋은 질문입니까?
댓글 10개
thanks for your input laptops aint my area i repair games consoles & retro audio , So according to the pinout map on a sata it's 3.3/5/12v yes i have a no HDD/SSD installed i have looked at the bios settings changed things back and forth to no avail security setting supposed to lockout hdd sync i cannot access have tried everything also tried 2 other drives that boot in my backup laptop , cannot workout whats happend it was working one day now it's not no trauma not dropped or moved , i will get the board version & number tomorrow & post tomorrow , thanks again ...... P/s cmos battery good
leslie brown 의
@lesliebrow19476 try a BIOS update and see if that gets your BIOS to see the drive again.
oldturkey03 의
@oldturkey03 How is that done via my backup ?
leslie brown 의
hello again' looking at a bios update the way it's done is when the Pc boots up , update is via Toshiba service site thats not possible the other method is by memory stick thats not possible , i am considering replacing the bios chip with a virgin chip since a bios chip is an Eprom it cannot be erased only with programming software which i dont have
leslie brown 의
@lesliebrow19476
If it goes to BIOS can you alter the boot menu to show USB 1st boot option and then insert a bootable USB recovery drive, save and restart and check if it finds the HDD?
jayeff 의
댓글 5개 더보기
