주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1502 질문 전체 보기
질문 마감됨
White screen after iPhone in water
Hello,
Last monday my iphone fall into water, but i dissambley it and put into rice for one day, but when i mount the iphone it power on ok but the lcd is white but the cristal touch works well. Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
javier, the number one thing to remember is that Rice is a great immediate assist, but not a cure. I would suggest that you clean your iPod properly to avoid corrosion failure later on. Use this guide to clean it. The guide was written for a 3G but all of it applies to your phone as well. After you cleaned it properly, I also suggest that you change the battery. I know that your phone works, but all this can stop once corrosion sets in. It will be a lot harder to fix then. Once cleaned reevaluate for any damage. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 309
