주요 콘텐츠로 건너뛰기
2018년 7월 출시, 15" MacBook Pro, 모델 A1989, True Tone 기술 15.4 inch LED-백라이트 화면, TouchID, 및 최대 Core i9 프로세서 여섯 개.
20 질문 전체 보기
After changing the battery my MacBook Pro won't boot up
I changed the battery on my 2018 macbook pro with a kit from Ifixit and now it's dead. It won't even try to start. I have dual boot with a one partition having windows and the other partition mac os. Before starting the repair, I set the mac os partition to be the automatic side to boot up and then followed the instructions to turn off the auto boot. The old battery was swollen and giving some problem but it had been working. The repair went perfectly, so I can't figure out what's wrong.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Check the MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable is not damaged as well as the ZIF connectors are latched per Step 1 in this guide 케이블 커넥터 인식 및 분리 here after re-inserting the ribbon cable we need to carefully fold the latch down to compress the cable.
Replace the small flex cable that connects the battery daughter board to the logic board. 이미지
제품
$14.99
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I checked that connection and the other ones too. Everything is fine. Can the cable be damaged even if it still looks good? I checked the battery voltage after charging it for an hour or two and there was no increase. So I don't think the battery is getting any power. Is it possible that something happened to my logic control board when I took it out?
@jms83415 - Over bending and sharp creases can damage the cable. Could you have damaged to ZIF socket? Post some pick on the connections here so we can see get in tight with lot of light.
As the battery was swollen and if the battery had already been replaced before then it’s possible the charging logic within the logic board is having issues.
Let’s get a better view of things install this gem of an App CoconutBattery post a snapshot of the apps main window here as well.
댓글 달기
답변을 추가하세요
jms 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 16
전체 시간: 51
