주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2003년 4월 뉴욕 국제 오토쇼에서 처음 공개된 2004년형 북미 모델로, 프리우스는 완전히 새롭게 설계되었습니다. 코롤라(Corolla)와 캠리(Camry) 사이의 차급인 중형 리프트백으로 거듭났으며, 기계 및 내부 공간의 재배치를 통해 뒷좌석 레그룸과 적재 공간이 크게 늘어났습니다.
ABS light has problems
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Herold, as bill was trying to say in his own inimitable way, you have't given us enough information to figure out what's wrong with your car, let alone come up with a fix.
What do you mean when you say the ABS light has problems? Are you just saying the ABS light is on? Or do you mean the ABS bulb is out? As you can see, with only the four words you said, we can't possibly know what the problem is.
If the light is on, you will need to get the ABS system scanned with a reader that can access it; a standard OBD-II reader won't be able to, so as much as I hate to, I would suggest going to a mechanic for a diagnosis. Wheel speed sensors are a common problem with ABS systems, but certainly not the only one possible, so a scan is essential for the proper diagnosis.
Update (01/23/25)
I might add that this is something that is important for you to do, being a safety feature of the car. Your Anti-Lock Braking system will not function as long as the light is on, and if your car is equipped with traction control, that will be disabled as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Herold Pierre 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 9
전체 시간: 177
