주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note20 Ultra 안드로이드 스마트폰에 대한 수리 및 분해 정보. 2020년 8월 출시.
Why won't my Note 20 Ultra get service?
My phone(N20U Exynos) isn't receiving a signal, so no calls/SMS/Data or even Emergency. According to *#0011#, it's telling me that 2 parts have gotten bad.⏎ but I have no idea what these 2 parts are, and idk where they are(remember, I am on Exynos and my motherboard parts are different than the iFixit teardown of the N20U)
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @damaj301damaj
What is the model number of your phone e.g. sm-N985?
Is the phone locked or unlocked?
If unlocked can you try using a different known working compatible SIM card to check if there's a signal?
Has the phone been dropped or gotten wet at all?
Hi @jayeff, my phone is an SM-N985F/DS.
Phone is unlocked and works with all carriers, I tried 3 simcards that are known working but they didn't work.
no the phone wasn't dropped nor it got wet, I had service, now suddenly out of service
댓글 달기
답변 1개
선택된 해법
Hi @damaj301damaj
Can you charge the phone OK using a USB-C charger?
Also try using the voice recorder app (record in stereo) just to see if that works.
Trying to prove if the problem is related to the charge port board e.g. loose flex cable connection, as some of the antennas for the phone are located on this board
If the above work OK then it may be a systemboard problem. Here's the SM N985F Service Manual that may help.
Go to p.38 (of 55 pdf) to view the GSM, WCDMA, LTE troubleshooting flowcharts and check if it leads to where the problem may be.
There are board layout diagrams on p.2→p.5. Use the search function in your browser to find the location on the board(s) of the components mentioned in the flowchart. You have to zoom in a lot to see them.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Yep, I can record using the voice recording app(both mics) work, and the USB-C charging/USB connection with PC/AA works perfectly, ama check the document you sent and see what to do
댓글 달기
답변을 추가하세요
Mohamad Damaj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 61
전체 시간: 794
