주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2024년 10월에 출시된 Apple의 인기 소형 폼 팩터 데스크탑 PC인 Mac mini의 세 번째 주요 재설계에 대한 수리 안내서, 분해 및 문제해결 정보입니다. M4 및 M4 Pro SoC와 최소 16GB의 통합 메모리가 특징입니다.
Upgrading Storage / restore step
I have a question about upgrading the storage on the new Mac Mini M4. I bought the base model. I have the 2T SSD card upgrade on the way from store.m4-ssd.com. I haven’t even turned on the mini yet. I am confident that I can switch out the SSD physically. But I am unclear about how to get the 2T SSD card to work. I don’t have an extra Mac lying around to use Apple Configurator. I do have a Surface Pro running windows. Can I restore the Mac mini from iTunes? The surface has 2 x USB-C® with USB 4.0 / Thunderbolt 4. So I would just have to download iTunes, run iTunes when I and connect the Mac mini to the surface pro, and turn on the mini in DFU mode. Do I have these steps right?
Or is the only way to do this is with another Mac?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
The required method is using the Apple macOS tool Configurator tool from a second Mac connected via a USB-C Thunderbolt compliant cable. Time to find a friend with a M series Mac who can help you out.
Reference:
이 답변이 도움이 되었나요?
점수 2
댓글 달기
As an alternative, if you have a Linux box lying around you can build the idevicerestore project. I used the same SSD from m4-ssd.com and used the idevicerestore project to flash the drive. Some distros have the binary present but I found the the version distributed did not detect the newer M4 models. After building from source the M4 was recognized and I was able to flash.
https://github.com/libimobiledevice/idev...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Sorry they won’t work here. Apple uses a serialization strategy which requires access to multiple chips within the system, similar to how the iPhone is protected.
의 공유
댓글 달기
답변을 추가하세요
Leanna Keightley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 67
전체 시간: 3,309
