주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SL 시리즈 기아 스포티지는 2010년 4월 아시아 및 유럽 시장에 출시되었으며, 이어 2010년 8월 북미 및 중앙 아메리카 시장에 2011년형 모델로 출시되었습니다.
Transmission 3rd gear Slipping
3rd gear slips occasionally between 30 - 40 mph. It's only momentary. How hard is it to replace a tranny solenoid in a 2013 Kia?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Getting it out will be a project, ESPECIALLY with an FF layout. You need to remove the engine to remove the tranny, which requires access to an engine hoist, as well as bumper and radiator removal on a lot of Hyundai chassis. You'll also need to remove the front driveshaft with FWD vehicles to pull the motor unless the bumper and radiator suffice. It's easier on an FR layout (or 4WD/AWD since they usually use an FR layout) since the driveshaft has to come out, but it's in line with the rear wheels, making removing it many degrees easier.
I would never rebuild a tranny these days, especially with the lifetime fluid bullshit the OEMs push. The lifetime is the mechanical warranty. Once issues like gear slip come up, they're hiding other major problems way too often to the point a complete rebuild needs to be done. This has become the norm that much these days with how often dealers claim the fluid never needs changing (you're supposed to do it every 50k miles!!!). It's just way too common of an occurrence on non-Aisin transmissions where it's never been done unless the car has 200k miles.
Buy a good reman tranny from Kia/Hyundai, or try your luck at a junkyard. You can't rebuild modern trannies that easily these days, and when they get to this point, there are almost always other issues waiting to greet you. It may end up totaling the vehicle out, depending on the resale. A lot of those 2011-15 Kia/Hyudais have the "100k mile resale" penalty, which makes big jobs sometimes cost-prohibitive. Something small is fair game, but not a big job like a bad tranny.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
MrKia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 449
