주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Matrix RV2310은 2023년에 출시된 지능형 자동 청소 로봇청소기입니다.
How to replace the brush motor
My roller brush motor is no longer working well. Keep getting the error that the brush is stuck. I have another unit that broke for a different reason and would like to swap the main brush motor, but would like instructions on how to remove and replace the motor on this model.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
this might help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
All of the videos on YouTube help you get apart the rest of the machine, except none tells you how to take the top of the shark matrix off. we found it easier to peel back the sticker top to get to the clips easier that you have to release to take the top off, see pictures.
이미지
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this problem as well. You will need to do a near complete teardown of the robot to get to the motor/gear assembly. Its pretty straight forward of you have the tools necessary. The only hidden aspect is the lock ring on the top. You need to remove the “Matrix” circular emblem off the top and then you get to that lock ring.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Hanovaman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 91
전체 시간: 1,271
