주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1347. 2011년 7월 21일 출시. Core i5 또는 Core i7 프로세서 탑재. 썬더볼트 포트 지원. 이 기기는 Mac mini 서버 구성으로도 사용됩니다.
Mac Mini resets itself
My Mac mini, 2.5GHz Dual Core i5 "Mid 2011" (High Sierra) resets itself several times a day.
 performed an NVRAM, performed an SMC reset, booted on Safe mode, changed memory module, without success
  I would really appreciate some ideas to start looking for the cause.
Update (02/15/25)
Found on this site:
"I disagree with the power supply diagnosis. Unless you have set your power save options to restart after power fail, the machine will stay off. Mine does not stay off. None of the others reporting this issue claim it stays off.
I was having the random restart problem several times per day after updating to High Sierra. The suggestions above caused me to start thinking about what functionality might change across releases. I decided to look at Power Save options.
I disabled power save for both system and display (set it to Never). The problem has disappeared. I have been running for a week now without recurrence.
It appears that Apple has introduced misadventure into the Power Save behaviour of (at least) High Sierra on Mid-2011 Mac Minis."
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Found on this site:
의 공유
댓글 달기
답변 1개
선택된 해법
What Apps are you running? Was one updated on you when you started to have issues? Remove any apps from your startup list to see if that helps.
You may want to review the Activity Monitor App under the Utility folder to see what’s running for processes and which are using more and more memory. See if the log file shows a crash event.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you very much Dan for your prompt and kind reply.
I will do as you suggest.
의 공유
댓글 달기
답변을 추가하세요
Pedro Miteff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 250
