주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG V60 ThinQ 5G는 LG V 시리즈의 일환으로 LG전자가 제조한 안드로이드 패블릿입니다. 2020년 2월에 발표되었으며 LG V50 ThinQ의 후속 모델입니다. 2021년 4월 5일, LG전자는 휴대폰 사업 부문을 철수하고 모든 잔여 기기의 생산을 중단할 것이라고 발표했습니다. LG전자는 기존 재고가 소진될 때까지 휴대폰을 계속 판매할 것이라고 밝혔습니다.
Right channel audio gone
The right channel audio does not work (bottom loudspeaker, right channel with wired earbuds. bluetooth is fine). I've had this issue for a while, and I decided I would replace the parts that (I thought) were defective. I replaced the bottom loudspeaker, the 3.5mm jack, and the antenna/sound board (I had also done other repairs during this such as replacing the bluetooth antenna, the battery, and the charging flex cable, all of those seem to be working fine now. It should also be noted that my flex cable replacement and the antenna/sound board replacement were ordered separately and did not arrive as one piece.) Even after doing all of that, there is still no audio coming from the right channel. I honestly don't know what to do now.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I have this problem too.
And after cleaning these two part with contact cleaner and cotton swab, both speaker and headphones works fine again.
이미지
이미지
However, after the fix, the phone can't connect to PC anymore. and charger with QC doesn't charge with full speed; it only reach full speed with PD charger. I guess I broke something during the clean.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
beaviszep 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 217
