주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 9월 출시. 모델 번호 A3028로 식별 가능.
Q30's won't turn on
Initially, the headset was switching itself off seconds after being switched on, during use.
Today, however, it didn't turn on anymore.
If I press the power button or the NC button, the blue light comes on. But it won't turn on.
When I plug in the charging cable, the red light comes on.
With the 3.5mm sound cable, the headset also works.
Does anyone know what might be happening and how I can solve it?
Service is not a possibility, because although the headphones are not yet a year old, I bought them through the official Anker website on Aliexpress and they refuse to provide repairs.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
How can I bypass the power button, in order to tell if that is the problem or a dead battery? I have a similar problem, but there's no light when the button is pressed, only when the headphones are connected to the charger
@tomasdiazaliste You can bypass the power board by using an AUX / 3.5 mm headphone cable.
댓글 달기
답변 1개
선택된 해법
@ynae sounds like you may have a power issue going on here. It sounds like you're saying it is all working except that it has that power issue. I would consider starting with a new battery first. Check all the wiring and the power switch while you work on that. Use this guide Anker Soundcore Life Q30 배터리 교체 to work on it. Let us know what you find out.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Can you tell me where I can find the replacement battery? I'll try to follow the tutorial. Thanks for your help.
@ynae all of that will depend on where you are. I would wait until you have the old battery. Then use the numbers on that to do a search. That way you know you will get the right battery.
댓글 달기
답변을 추가하세요
Ynaê 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 98
전체 시간: 2,007
