주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
공식적으로 Chevrolet C/K라고 불리는 C/K는 General Motors에서 제조하고 Chevrolet 및 GMC 브랜드로 판매된 트럭 시리즈입니다. C/K 라인업에는 픽업트럭, 중형 트럭 및 대형 트럭이 포함됩니다.
Water pump replacement time
Water pump replacement timeframe
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@kodyarnold what is the year, the model and what engine size?
의
댓글 달기
답변 1개
선택된 해법
When it starts leaking or making noise. I'm not aware of any kind of recommended replacement interval like there is for timing belts or oil changes.
Update (03/13/25)
No problem, Kody. I don't know the details of your rig yet, but on my son's 1985 GMC High Sierra (K2500) with a 350 ci engine, it's a pretty straight-forward job. Once you have the belts out of the way it shouldn't take more than a half hour or so; add another half hour for the belt R&R and an hour should be enough time.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I meant the time frame to actually fix it not when to replace it my bad
의
Yeah sounds about right it’s a 98 but it’s also a 350 so I assume not much change besides maybe the water pump part itself but I believe they are in the same common area
의
@kodyarnold Yep, not that much difference in that area. If you've ever had to replace a water pump on these new models that use the timing belt to drive the pump, now there's a pain in the behind. I'd much rather have one out there sitting proudly on the front of the engine where you can actually get to it. On my son's truck I can climb on in the engine compartment to work on it.
의
댓글 달기
답변을 추가하세요
Kody Arnold 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 295
