주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
북미 지역에서는 Canon EOS Rebel XTi로 알려진 XTi는 2006년에 출시된 10.1 MP 센서를 탑재한 보급형 Canon DSLR입니다. EOS 400D 및 EOS Kiss Digital X로도 알려져 있습니다.
How do I fix an error 99?
I got an error 99 a couple of months ago and have done everything I can but the error doesn't go away
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
This typically means the camera software does not recognize the lens.
To fix this: 1. Make sure the lens is compatible with the camera. 2. Using the eraser of a pencil, gently rub the contact surfaces clean on both the camera and lens. 3. Remove and reinsert the battery, attach the lens and turn the camera on. This should fix the problem.
Also, Canon has a troubleshooting section for all of their product on the web site.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Former Canon DSLR repair tech here. I know I'm late to the party, but here's my take:
Error 99 is a general, catch-all error that usually signals some sort of hardware issue - it is like the "Idiot (Check Engine) Light" in a car.
From what I can remember, it's usually a couple of things: CMOS bad, shutter failure, or the lens isn't functioning properly (in that case, usually the focal aperture blades are stuck).
I'd troubleshoot it as follows:
1) With no lens attached, turn the front of the camera to you (so you can watch the shutter) and try to take a picture at the fastest exposure speed. If this throws an E99, the shutter or CMOS is likely going bad / failing. This will be difficult to fix because Canon no longer services those models (XT & XTi).
2) If it passes Step 1, attach a lens and try to take a picture. See if you get the error. If so, the lens needs to be repaired.
3) Repeat Step 2 with every lens you own, until you get the E99.
Hopefully, one of those steps will help you figure it out.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
irwin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 53
전체 시간: 337
