How to remove a stuck bit?
I tried to disassemble the Steam Controller with the Moray Precision Bit Set, but one of the bits got stuck and I couldn't get it out.
이미지
이미지
How do I remove the bit?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
How much room do you have between the walls of the controller and the bit itself? You could try and slip a set of Tweezers in there. Or you could try and use a strong magnet to pull the bit out.
의
@jmehnert I tried but there isn't enough room.
The magnet I have isn't strong enough, maybe I'll buy a stronger one and try it.
의
댓글 달기
