주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Screen turned off permanently.
Hi Team, the screen for Fitbit Inspire 2 has turned off permanently and not coming back. Although the vibration as well the sensors and the device on/off/restart are working fine from the inside. As the screen is turned off completely i cant even pair it with any other device too. Please help. If there is any facility inside India where i can send my Fitbit Inspire 2 and get the screen replaced. Do let me know.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
My mom is having the same problem.
Also, prior to the issue, her screen was extremely dim. To assess the device, I had to take it into a darkened room.
I restarted the device:
1. While connected to a charger, hold down the side buttons for 15 seconds until the smiley face appears.
After restarting, the smiley face was the only content to appear on screen, no watch face appeared. However, just at the OP experienced the device HR sensor lights, and the device gives haptic feedback (vibrates) when buttons are pressed.
댓글 달기
답변 2개
You should try to contact Fitbit and see if you can get any service done. Also check your local repair shops and see if they can replace your screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I haven't tried yet, because I don't have the device with me, but I read somewhere that you could try using a synchronized device and change the watch face settings. That might cause the display to reset and reappear?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tribikram Behera 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 36
전체 시간: 319
