주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asko Appliances AB는 냉장고, 식기세척기, 세탁기 등의 가전제품을 생산하던 스웨덴 기업입니다. 베스트라예탈란드주의 바라 지방 자치체인 융(Jung)에 본사를 두고 있었습니다. Asko Appliances는 현재 중국의 대형 가전 제조사인 Hisense의 일부인 Gorenje 그룹이 소유하고 있습니다.
What is the Error code E10
what is the Error code E10 for Asko Dishwasher and how to fix ir.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
What is the model number of your dishwasher? Asko makes quite a few different ones, and getting you the correct answer depends on which one you have.
Knowing the model number is essential in this case, as a general search for Asko dishwasher error codes shows that most Asko DW's use error codes that start with "F" rather than "E", so we'll need to confirm.
The only result I came up with that seems to be close is a video on YouTube describing an Asko DW with an E10 error code. They claim it's a water level sensor error, which could be the sensor itself, the wiring going to it, or an issue with the control board. The only real helpful information they have to offer is to tell you to turn off the dishwasher, unplug it for a full minute, then plug it back in and see of that helps. If not, they say you should then call a technician. :-/
E10 Error on Asko Washing Machine - How to fix - YouTube
Update (04/10/25)
A search for Asko documentation on your dishwasher turned up a user manual, which includes a troubleshooting section listing error codes.
User manual Asko DWCBI241.S.AU (English - 46 pages)
Here's the information relevant to your problem.
The Care and cleaning section has this information on clearing the drainage pump.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for your prompt reply. Sorry, the error code would be F10 and model number is DWCB1241.S.AU
의 공유
댓글 달기
답변을 추가하세요
Rashedul Alam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 30
전체 시간: 463
