주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 설계한 M2 Pro 및 M2 Max SoC를 탑재하고 올해 1월에 출시된 16-인치 MacBook Pro의 수리 안내서 및 분해 정보입니다.
Replacing M2 Screen: Pro Lid Angle Sensor and True Tone
Hi, thanks in advance.
I’ve been reading online, but I’m still not sure about one thing:
When replacing the screen on an M2 MacBook, do you also need to replace the Lid Angle Sensor, or is there a way to calibrate it instead?
Also, is True Tone completely unrecoverable after a screen replacement?
Thanks again!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The source of the part is the issue with display replacements:
  • A virgin display from the back of the factory won’t have its firmware installed as Apple does this at the point of system assembly, so it won’t have a working camera.
  • A used display will have the firmware, but TrueTone won’t work (at least that is what we have seen with the M1 models).
  • Getting the display from Apple gets you access to the paywalled calibration tool so all of the system is calibrated.
As far as the angle sensor reusing it when you replace the display is not an issue. If you are replacing it as it was damaged we hit the same issues like I expressed with the display.
Now here’s an interesting tidbit I haven’t verified yet! Let’s say you get a used display and you ordered a replacement angel sensor from Apple at that point you’ll gain access to the calibration tool, I was told the display will be recalibrated with the new sensor at which point regaining TrueTone. If you do this let us know! As that would be a way around Apples lockout.
So here’s the self repair site to order the needed parts, first referencing the online service manuals also linked within the site Apple Self Repair Store
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Hello, great idea.
How can I verify if True Tone works or not?
@mirkounchained - within the display settings Use True Tone on Mac if the setting is missing then you’ll need to try the angle sensor trick!
I am going through the same issue. Did truetone work after doing the calibration just for the lid angle sensor? Truly appreciate any insight on this
FYI an Update, it does not work. I bought a new lid angle sensor through apple self service and they did the calibration online. It only calibrated the lid angle sensor. True tone remains disabled. %#*@ you apple!
@kesharawee63231 - Bummer! I had a feeling it might not work.
댓글 달기
답변을 추가하세요
Mirko Unchained 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 62
전체 시간: 1,299
