주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blinking red power light
The red power light blinks and the TV won't turn on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Hey there!
First of all, do you have the TV series and model number? It will make diagnosing the problem much easier. However, from what I can tell, a flashing red light indicates a power supply or internal component issue. Try first to check your TV's power cord and your outlet to see if anything is wrong with them. You can also try to run the TV through a power cycle. You can run a simple power cycle by pressing and holding the power button on the remote for 5 seconds, or unplugging the TV from the power outlet for 30 seconds before plugging it back in. Finally, try checking your TV's connections (eg. HDMI, AV).
If all else fails, try to check if your TV is still under warranty and go from there. You can also contact Samsung Support, and they will try to diagnose the problem with your TV. You are also welcome to try to open up the TV by yourself and fix it, but I wouldn't recommend it for many reasons.
Best of luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes it won’t and I’ve tried many times
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricardo Figueroa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 36
전체 시간: 342
