주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
칩 내부에는 무엇이 있을까요? 어떻게 작동할까요? 컴퓨터 칩은 집적 회로, 모놀리식 집적 회로, IC, 칩 또는 마이크로칩이라고도 불립니다.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
의 공유
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
의 공유
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
의 공유
댓글 달기
답변 1개
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
의 공유
댓글 달기
답변을 추가하세요
TechVid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 261
