주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1999년형 Chevrolet Malibu는 General Motors(GM)에서 제조한 5세대(1997-2003) 모델입니다. 이 모델은 1980년대 초반 Malibu 라인업이 일시적으로 단종된 후 GM에서 다시 시장에 선보인 첫 번째 소형 전륜구동 Malibu입니다.
Why is my car lagging?
The car has a problem shifting gears and lags so much even a slight elevation is a challenge to clear.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
We need more details - is the CEL on? If it is on did you scan it? Id it just struggling without codes?
댓글 달기
답변 1개
가장 유용한 답변
Without codes or any clues like climate, we will be limited here. We'll need more information like your climate and if you scanned the car, to give you an idea. Get the car scanned so we have more to work with. A scanner like this is plenty for you. Same as before, but offers bidirectional control.
The first thing I would check is the air filter. Have you changed it recently? If not, and it's more than a few years old, I would go ahead and try that first—NA engines and clogged filters do not get along and will behave this way. You can probably find this from your local auto parts store - this will run you $10-20.
The next thing I would look at is the MAF sensor—again, a bad MAF will do this.The quickest way to test this is to disconnect it, drive the car, and see if it behaves any better. If it does, then you have confirmed that the MAF sensor is bad.
NOTE: This test will trigger a CEL code, so get a cheap scanner before trying this. In addition, without a MY, we can't locate the part# for you - in lieu of a MY to locate it, search this: "XXXX(MY) Malibu MAF sensor".
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
John Manegene 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 178
