주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mitsubishi Lancer 8세대 모델.
2002 Lancer CK5A Window not reciprocating
I've bench tested the regulator and it's working. The switches driver window relay clicks in both switch directions yet the window still doesn't move. I'm open to any ideas or wiring diagrams.
Cheers team.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
@andrewmorg21490 "bench tested the regulator " is that including the motor? Besides clicking, have you checked the relay?
의
Yeah, motor works as it should. Moves the cable up and down on its path. I'll take the switch apart and come back.
의
The "auto-sw" arm was in the wrong position making the switch not work at all. I'll put it all back together and see if it stays fixed 🤣
의
Looks good and works good. It's a silly little 3mm plastic tab the switch is meant to hook on to. Out of all things...
의
댓글 달기
답변 1개
선택된 해법
It's a little ~3mm plastic tab the switch is meant to hook on to, and it should be aligned with the outline on the PCB.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andrew Morgan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 244
