주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
My DSi only works while charging.
Tried playing a game on it a while ago, and when the charger is plugged in it works perfectly fine. When it isn't, it discharges very quickly (not immediately, but definitely in less than a minute). I haven't opened it up yet, because I don't really know what to look for and how to know for sure if the battery is the problem.
What could the issue be + what do I look for to see if that's the case with my DSi in particular?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Sounds like a battery issue. The DSi is now 17 years old, and even the best batteries would have deteriorated after such a long period of time. Swapping the battery is pretty easy on the DSi, compared to modern devices that features glued down batteries. All you have to do is locate the really obvious battery door on the bottom of the DSi, turn a few screws, and you would have access to the battery, which simply pops out like the one in Nokia phones.
Here's the guide for it:Nintendo DSi battery replacement
There might be corrosion caused by a leaked battery, though, if the battery had remained untouched since you first bought it. In that case wear gloves and remove the battery ASAP. Then use cotton swabs dipped in isopropyl alcohol to throughly clean the whole area. If the issue still persists, you might also consider taking it apart and replace the power board, as there is usually rust on the contacts if the battery has indeed leaked, causing batteries to drain fast. Here's the guide for it:Nintendo DSi power board replacement.
If a new battery and power board didn't solve it, then the issue might be motherboard related, caused by corrosion on somewhere else other than the power board. That is the worst case scenario, and it makes the whole repair much more complicated. Take the motherboard out entirely with this guide:Nintendo DSi motherboard replacement, inspect for signs of corrosion(white stains, sticky stuff, anything out of ordinary), and gently brush that area with a toothbrush dipped in isopropyl alcohol. Hopefully that will get rid of the corrosion. If not, you might consider getting a new motherboard, since repairing the old one would require delicate micro soldering.
But again, it might just be a defective battery.
Get yourself a new battery first and me know if this solved your problem!
Nintendo DSi 배터리 이미지
안내서
닌텐도 DSi 배터리 교체하기
난이도:
쉬움
2 minutes
Nintendo DSi 전원 보드 이미지
안내서
Nintendo DSi 전원 보드 교체
난이도:
조정
Nintendo DSi 마더보드 이미지
안내서
Nintendo DSi 마더보드 교체
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hi!
Doesn't seem to be a leak of any kind, and I nearly ordered a new battery but when I removed the current one to take a look and put it back in, suddenly I didn't have this problem anymore! I suppose sometimes things work out that way.
Thank you for answering though, I suspect something will go wrong eventually and I'll have to come back and refer to this haha
Yeah, that's pretty common with Nintendo consoles. They often fix themselves. I guess the problem could be either loose contacts, corrosion of some kind, or a number of other mysterious things. Anyway, I'm glad you fixed it!
댓글 달기
답변을 추가하세요
melonyellow 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 25
전체 시간: 403
