주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
macOS 호환성을 갖춘 LG 27인치 UltraFine 5K IPS 모니터
Suddenly completely dead - even fan doesn't work
Suddenly acts as completely dead - swapped out cables and power with another same monitor which works fine - still dead. My uneducated guess would be power supply or similar - how to check and repair?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Hi @osdoctor
Check if the T5A 250V fuse on the power adapter board is OK or not. With the power disconnect from the monitor use an Ohmmeter to check it is tests 0.00 Ohms i.e,. short circuit and not OL or infinte Ohms i.e. open circuit.
If it has blown then there's a reason for this to happen as normally fuses don't fail of their own accord, so further testing on the power board for a start would be required.
Note: Ensure when you get a replacement fuse, that you get a T5A 250 axial fuse and not a 5A 250V axial fuse. The T rating is important, as it signifies that it is a slow blow fuse and not a normal fast acting fuse. If a fast acting fuse was inserted it would blow immediately that the power was connected, due to the high inrush currents that flow, whereas a slow blow fuse will hold for the duration of the inrush current i.e. 5-8mS, before they subsided back to normal.
If you decide to take a chance and simply replace the power adapter board, search online for the LG part number which is on the board. Looking at the image in Step.7 of the ifixit LG UltraFine 5K 분해도 guide, showing the AC-DC adapter module the part number is EAY65288601 but this doesn't mean that the same board is used in your monitor so check first.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your monitor is completely dead, even with known-good cables and power, it's likely a failed internal power supply. Open the monitor (carefully) and check for blown capacitors (bulging/leaking tops), burnt components, or fuse issues. Replace faulty parts if skilled; otherwise, seek professional repair to avoid electrical hazards.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
osdoctor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 36
전체 시간: 561
