주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1994년 12월 3일 일본에서, 1995년 9월 9일 북미에서 출시되었습니다. 모델 SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, SCPH-900x가 있습니다.
My laser doesn't work
I tried to understand what is the problem, and maybe i have the solution too, but firstly I want to be sure of what I'm fixing, before I take another laser that costs money ☺️. The CD doesn't spin, but it seems that this is due to a lack of power coming from the mother board. On the cable that comnects the mother board to the optic group there is a little black dot. Chatgpt says that it is a burn caused by some sort of electricity malfunctions.
Can anyone help me?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Hi!
It's hard to say without photo's. Can you share them with us?
Anyway, it's possible that some capacitors failed on the motherboard and prevent the Playstation it's drive from working.
Also, the laser could have failed.
But before we can tell, we really do need pictures.
Thanks!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi there!
thank you for your answer, really appreciate it. This is the photo of the black dot on the cable. Tell me if you need more, thanks for your help!
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My pleasure! Thanks for the photo! This is not a burn mark. This is straight from the factory. Some ribbons do have marks (rare, but it’s there). Most likely thing is that your laser just died or starting to die. I would replace the laser deck as complete. A new laser deck comes with everything, including a new ribbon cable. The cable is fused, so it cannot be replaced (everything is replaceable, but it will be VERY difficult). The only thing you need to transfer is the power cable, and that’s it.
의
댓글 달기
Here there are some photos of the motherboard, if you see any problem let me know. Thanks for your answer by the way, I just want to be sure making you see these pictures, even if I think it seems ok. Thank you very much!
이미지
이미지
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi again!
The motherboard looks fine, but it is modded. Be aware that a broken modchip can cause issues with reading games. So it’s either your laserdeck or the mod chip.
의
댓글 달기
답변을 추가하세요
Francesco Avantario 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 254
