주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nespresso Pixie는 원두 가루 대신 캡슐을 사용하는 소형 커피 머신입니다. 단 25초 만에 예열 및 커피 추출이 가능한 1인용 커피 머신입니다.
Where does this piece go!
이미지
I followed video on how to take apart machine to clean diffuser plate, put back together and have a black plastic piece left over. Have seen others with same problem but no-one has an answer. It would make my day to know!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
The part is a component of part no. 24 in the explosion view above.
It is one of the covers of the electronic control board.
It is located at the top area of the PCB cover, just where it goes behind the thermoblock.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thank you so much. At last, the mystery is solved. Youtube had many posts asking the same question but the video creators never answered. When I rally the enthusiasm I'll take the whole thing apart again and replace the missing piece.
hey, rate somebodies answer, please.
댓글 달기
here is a parts breakdown, but I don't see anything like it.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It's part of number 24.
댓글 달기
If you solved the mystery, would you please show where this piece goes as I have the same problem? You'll make my day too😅
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I'm afraid I couldn't be bothered to take the Nespresso machine apart again, and all the diagrams available online weren't clear enough to show where the piece went. The machine works (twice as loud) so I think the piece stopped vibrations. It also leaks during use so is now sat in a tray to catch the water. I believe that after cleaning the parts which were cakes with coffee, I then put pressure on the O ring which many posts said you have to replace eventually. I can't be bothered to do this as once again it would require taking the whole thing apart. If you are happy to, I would suggest watching a video on replacing the rubber O ring, so you can do both repairs at the same time and be done with it.
댓글 달기
답변을 추가하세요
poisonivy@saintly.com 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 59
전체 시간: 645
