주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 8월에 출시된 Galaxy Tab S6 수리 안내서 및 지원 문서입니다. 모델 번호: SM-T860NZAAXAR
Battery port burn out
I was charging it one day and when I un pluged it it was very hot and from that day on it didn’t want to charge
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
That's a tough one; there are several possible issues that could cause the problem you're seeing. The good news here is that if it's a problem with the charging port then that can be replaced fairly easily, as the USB port is mounted on a separate daughter card that you can buy online. I found a guide showing how to do that replacement.
Manuales / Samsung Galaxy Tab S6 / Auxiliary board - Nadie Me Llama Gallina
That's where I'd start, personally. Depending on the condition of the battery, it may well be worth your time to replace it as well, especially if the daughter card doesn't fix it. Following that, there's a flex cable connecting the auxiliary card to the motherboard that could theoretically be the issue that would be the final thing to try. Here's a guide to replacing the battery.
Manuales / Samsung Galaxy Tab S6 / Drums - Nadie Me Llama Gallina
If nothing above works, then that just leaves the power management chip on the motherboard. Fixing that would require board-level repairs that would take quite a bit of expertise and specialized equipment; at that point you may well be better off looking for a new motherboard instead.
Good luck; let us know how it all turns out!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kevin Urrutia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 184
