주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1708/EMC 3164 — 2017년 6월 출시, 이 보급형 MacBook Pro는 기존의 펑션 키를 그대로 유지합니다(OLED 터치 바와 대조적).
Why am I getting weird artifacts?
As the picture shows, there are white dots on the external display, the internal display is broken. These dots are not still, they move around the screen and sometimes a large part of the screen sometimes is covered in artifacts of all colors. This stopped for a short period of time where it connected and worked flawlessly and began again going into recovery mode and now I cannot stop it. Now with these arficats, it does not connect well and disconnects from the HDMI often. Any help is appreciated, thank you.
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
@danj Is this a sign that the Internal graphics are failing? As I have also noticed this happen on an older Macbook model that I had here recently......? The internal display not working can be the flexgate issue https://www.lappymaker.com/blog/flexgate...
의
@livfe - This is not a FlexGate issue (backlight failure) or some other version of it effecting the video. From 2016 onwards the logic board pumps out iDP or eDP signaling to the display to then convert to the raster image (T-CON). Pixel lice is either within the RAM or at the T-CON not in the transmission between.
의
One thing I'd also check is whether the artifacts appear before macOS fully loads, such as during startup or in Apple Diagnostics. If they do, that usually points away from a software issue and more toward a hardware fault. Since the external display is showing the same pixel artifacts and randomly disconnecting over HDMI, I'd suspect the GPU, VRAM, or display output circuitry on the logic board before replacing the LCD. A board-level inspection is probably the next logical step. I found this troubleshooting guide useful for similar laptop and MacBook repair cases: https://itworldthecomputeritsolution.in/...
의
댓글 달기
답변 1개
선택된 해법
I call this effect pixel lice as the video buffer RAM is failing or there is noise within the T-CON board.
The different model series use different memory setups. In the Intel models we have either iGPU (Intel CPU graphics) or dedicated GPU's mostly AMD these days.
The Intel based systems carve out a bit of main RAM as the buffer space and within the AMD models dedicated RAM.
Now to make your head spin! The AMD chip isn't used during startup and only pressed into service when a given App calls for it. With nothing running other that the OS will be using the Intel graphics so if you are seeing pixel lice just within the desktop that's a bad T-CON board. If you see the pixel lice when running a heavy graphics game or task like video editing that's a dedicated RAM failure often it's a bad solder joint on the RAM chips.
Of course the T-CON is often where the failure is, as it's part of the display within the lid or just dangling as in this series there is not much you can fix. If you have some spare parts you might be able to replace if you can identify the failed component. It's both simpler and cheaper just replacing the display.
이 답변이 도움이 되었나요?
점수 1
댓글 10개:
@danj It is an Intel only laptop to my knowledge, and it happens on startup, as I do not have any spare parts apart from a 2012 macbook pro, would I be able to use the T-CON from that or would I be forced to replace the internal display. Thank you.
의
@cperson - Sorry I forgot to clarify, yes indeed your system is an Intel Graphics only system.
In your series the T-CON is dangling from the display sitting within the main body. I would just replace the entire display as the really can't fix's that much within the T-CON it's self. MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here's the guide MacBook Pro 13" Touch Bar 2017 스크린 교체
의
@danj Will that fix the issue entirely?
의
@cperson - It should!
의
@danj Thanks, I will try this
의
댓글 5개 더보기
댓글 달기
답변을 추가하세요
Cperson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 14
지난 30일: 31
전체 시간: 596
