주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 15-3511은 Dell에서 제조한 보급형 노트북입니다. 이 모델은 10세대 및 11세대 Intel 프로세서를 탑재하고 있습니다.
Ac adapter not installed
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@beviswulff I assume that your laptop is telling you that. Is it the original AC adapter? Have you checked the voltage on that? What have you checked?
의
댓글 달기
답변 1개
가장 유용한 답변
Check the sense pin - Dell laptops are super picky about that, ESPECIALLY ONES that preclude USB-C only charging. You'll need a new AC adapter if it looks damaged or missing.
If the pin is fine, then I would get a multimeter like this(1) and check the adapter. It should be 19.5V or better without a load - sometimes 20V or more. If it shows less then this without a load the adapter may be slowly failing, or work but have issues with high spec machines. This is what one I tested showed me:
이미지
이미지
If the adapter is fine, the jack inside the laptop is damaged. PartsPeople sells it, and you can get it all in for ~$23. It's not hard to install. Dell has the SM online for this machine.
(1) - You can get away with using a cheap $20-30 meter from a big box store like Walmart, but they are unsafe to use on anything beyond low voltage DC applications. I don't recommend any of them and the least I ever recommend is a True RMS Klein (with Fluke being the best, albeit expen$ive) but it's an option. But I can't recommend any of them in good conscience.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bevis Wulff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 507
