์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
2020๋…„ 3์›”์— ์ถœ์‹œ๋œ ์ธํ…” ํ”„๋กœ์„ธ์„œ๊ฐ€ ํƒ‘์žฌ๋œ MacBook Air ๋ชจ๋ธ A2179์˜ 2020๋…„ ๋ฆฌํ”„๋ ˆ์‹œ ์ˆ˜๋ฆฌ ๋ฐ ๋ถ„ํ•ด ์ •๋ณด์ž…๋‹ˆ๋‹ค.
MacBook Air shuts off randomly when on battery power
For the last year or so, this Macbook Air has been shutting off randomly when it is on battery power. This happens at various charge levels, as high as 70%. When this happens, it can only be turned on after plugging it in, however once it is plugged in, it turns right back on and immediately shows the screen as it was before the shut-off. It can then immediately be unplugged and used on battery power for a long period of time. This happens after about 1-2 hours of activity while using the laptop on battery power only. I have tried SMC and PRAM resets, as well as restarts. The system has had no liquid damage or drops that I am aware of. Thank you very much!
๋‹ต๋ณ€๋˜์—ˆ์Šต๋‹ˆ๋‹ค! ๋‹ต๋ณ€ ๋ณด๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ 1๊ฐœ
@danj Thank you so much! I just completed the check with CoconutBattery and uploaded the pictures with the laptop both plugged in and unplugged. I will try to take off the bottom plate to inspect as well.
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 2๊ฐœ
์„ ํƒ๋œ ํ•ด๋ฒ•
Well... it does look like the battery is on its last legs๐Ÿ™ here we can see the load cycles are 862, at best you can get to 1000 which is the limit. But not all battery's make it that far. Age and if the system is mostly used tethered to AC most of the time ~800 is about the limit when things start acting up. Even the Battery Health is already in the Red as well. Then we get to the batteries temp this battery is running Hot! Which is also not a good sign 30ยฐC is about the point of cutoff. Note the charge Wattage is slightly less than the discharge. If you were to put the system into sleep or better yet shut it down fully the loss of the load would allow the battery to fully charge (at least what is was able to).
Think of it this way the bath tub is draining faster than you are filling it! But that will only buy you a bit more time.
Here's the needed part MacBook Air 13" (Late 2018-Early 2020) Battery and here's the guide to put it in MacBook Air 13" Early 2020 ๋ฐฐํ„ฐ๋ฆฌ ๊ต์ฒด
Replace a 4379 mAh battery compatible with MacBook Air 13" (Late 2018-Early 2020). 49.9 Watt Hours (Wh), 11.4 Volts (V). ์ด๋ฏธ์ง€
์ œํ’ˆ
$99.99
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 1๊ฐœ:
This is extremely helpful, thank you so much! I will work on this, I am so grateful for your help.
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
Your Battery maybe failing. Download this gem of an App to get a better idea what's happening CoconutBattery. Take a snapshot of the Apps main window so we can see the details posing it here.
Have you removed the bottom plate to inspect things? You might want to do that as one cell maybe swollen.
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Robert ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 8
์ง€๋‚œ 30์ผ: 30
์ „์ฒด ์‹œ๊ฐ„: 139
