Haptic feedback motors not functioning
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이미지
Recently replaced my joysticks with tmr ones. The joysticks work. I know I have the correct order on the wires but the haptic motors not longer function. Any advice on how I might troubleshoot or narrow down what is the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Hi Eric!
Soldering work looks fine!
Please check the cables if they are fine. Are both stopped working now? Or just only 1?
Can you share a picture regarding the haptic motors and their cables?
Thanks!
의 공유
I have added photos of the wires. I desoldered the wires the other day and did test for continuity with a multimeter and the meter beeped for continuity so I think the wires are fine, but I hope this helps.
의 공유
Also it is all for. I tried dual sense tester, steam's controller function check, and a website called online mic test that has a tester for vibration. I get no function from either the soft or hard rumble that dual sense tester lists.
의 공유
All looks fine, everything is soldered correctly and the soldering work looks fine as well. Is the controller also up to date? Does it work when connected to the Playstation? Anyway, it's possible that a component died on the motherboard, as both of them aren't working.
의 공유
댓글 달기
