주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GeForce RTX 4080은 고사양 게임과 전문적인 작업에 필요한 뛰어난 성능 향상과 고급 기능을 제공하는 NVIDIA의 그래픽 카드입니다.
Rethermal Pasting and padding
Hello,
Is it possible to rethermal pad and paste this graphics card? my temps for the gpu are around 66 degrees Celcius under load however the Hotspot temps are around the 110 degrees Celcius mark. This card is not very old but i had taken it apart to replace the fan due to faulty bearing so dont believe i can send it in under warranty or anything like that. I am quite knowlegable when it comes to computer services and all that but im not really sure how to go about doing this. Any help would be GREATLY appreciated as i cannot afford to go buy a new card in this current market and cannot find another 4080.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Yes, you can take the cooler off and remove the thermal paste, then re-apply some new thermal paste.
But however, 66 degrees celcius is fine. 110 is pretty high, but when did it hit the 110? What does the monitoring tell you? Do you have screenshots?
Also, returning it for warranty is fine. Unless you broke or damaged something or removed any warranty sticker.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
charles.bailey@live.com 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 79
전체 시간: 897
