주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
동명의 사회적 기업에서 제조한 Fairphone의 5세대 모델입니다. 2023년 9월에 출시되었습니다.
NFC chip replacement query
My NFC chip is faulty. I've done all the tests including the onboard hardware ones, but no success, so time to replace if I can.
does anyone know where it's located and if/how I can swap it out?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hello,
Just a sanity check first,
  • did you run the test with a NFC card you know has worked in the past, and / or works with another phone?
  • update the OS, and reboot the system (sometimes android fails to initialise NFC)
  • re-seat the battery to re-seat the NFC antenna?
The Fairphone 5's NFC antenna is a built-in part of the battery, (pins 3&4 on the battery connector.)
so you are able to swap out the antenna by swapping out the battery.
But the actual chip itself is soldered to the main board and is not designed to be user serviceable without considerable skill and tooling
the schematics list it on page 40 as U3902 and on page 76 as ST21NFCD/ST54F
Your best bet to restore this functionality is to contact Fairphone support directly and ask about a warranty repair
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andy Wilkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 71
전체 시간: 530
