주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10세대 Corolla(E140/E150)는 2006년 10월 일본에서 출시되었습니다. 일본에서는 폭이 좁은 변형 모델이 제공되었으며, 더 넓은 버전은 국제적으로 판매되었습니다.
How do I fix the timing
My car doesn't qant to start, I suspect the timing needs to be reset
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개:
Without more info, background maintenance, etc, anyone can make guesses but might not answer your generalized question. Are you able to test for spark and fuel? One way to determine which one is suspect would be spraying starting fluid into the throttle body and try starting. This presumes battery, battery cables and their connections are fine and the drive belt is tight for the alternator.
댓글 달기
답변 1개
I would say you are wrong. "Timing" would be off my chart as a possible cause.
The more common things would be Battery, spark, & fuel. Of course, if the timing belt broke, that is a whole nother problem.
BUT, if the only thing you have to offer is your suspicions vs actionable symptoms and observations, you need to call a mechanic.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Godfrey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 130
