주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2003년 5월부터 생산된 Gigabyte 노트북에 대한 수리 안내서 및 지원 정보입니다.
Need help choosing what part to replace.
이미지
이미지
이미지
I need help figuring out which part I need to order. I already ordered a new power jack (https://www.ugparts.com/gigabyte-a5-k1-x...) since I'm pretty sure it was the burnt out part but now that I look at it, I might also need the board/connector as well. I'm pointing out the capacitor(?) that burned out with the screw driver.
Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi!
Can you remove the board and also sent pictures from the other side?
I would just completely replace the board. Cables are usually fine (if not sure, please share some pictures with us regarding the cables).
Those board are usually for sale. You can try Gigabyte first and ask them, otherwise you can check on AliExpress.
Usually numbers should be writting on the board so you can check the part number.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I got my daughters each one of these laptops the board is poorly designed and will eventually stop working. I took inspiration from my RC hobby and created my own dc jack using EC5 male and female connectors. Since it connects to the motherboard with a cable with 8 wires it was simple enough to solder them together then add on the 12 AWG EC5 wires. Then doing the opposite on the charger as well now my kids can play on their laptops without fear of shorting out that little daughter board anymore.
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If any one is looking for the specific daughter board part I got it from here and it fixed my issue:
https://www.aliexpress.com/item/10050099...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Drh21 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 21
전체 시간: 283
