주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteBook x360 830 G6는 약 1.36kg(3lbs) 무게의 13.3인치 알루미늄 디자인 노트북입니다. 이 노트북은 노트북과 태블릿의 기능을 동시에 수행할 수 있습니다.
Error after failed update bios
after update bios automatically
"My laptop's touchpad isn't working after shutting down. To get it working again, I have to close the laptop lid and open it again."
"My laptop always switches to tablet mode even when it's in laptop mode. And when I switch to tablet mode, the keyboard and touchpad still work, which makes it impossible for me to hold it like a tablet normally."
"And the Num Lock light is always on, even when the laptop is turned off. This issue seems to be connected to all the problems I'm experiencing. It has only returned to normal a few times, but after a few hours, it goes back to this state."
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
Hi @razors80198
Try this
go to:
https://ftp.ext.hp.com/pub/caps-softpaq/...
Use HP Image Assistant (HPIA)
to download and install the correct drivers and bios update on your pc.
Run the tool and click Analyze
Allow for some time to capture system configuration,
and install all packages that was listed on it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
After a failed or incomplete BIOS update, my laptop started acting abnormally. The touchpad stops working after shutdown and only resumes function when I close and reopen the lid. It frequently switches to tablet mode even when in laptop position, and oddly, the keyboard and touchpad remain active in tablet mode, making it unusable. Additionally, the Num Lock light stays on even when the laptop is completely powered off. These symptoms seem interconnected, possibly indicating firmware corruption. The system occasionally returns to normal, but the issues always come back after a few hours, suggesting the BIOS update didn’t apply correctly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Your BIOS update likely caused power-state errors. Try this:
  1. Hard reset (unplug, hold power 30 sec).
  2. Update touchpad drivers in Device Manager.
  3. Disable auto tablet mode in Windows Settings.
  4. Reset BIOS to defaults (press F2/DEL at startup).
  5. Check for newer BIOS updates from manufacturer.
If problems continue, contact support—you may need a BIOS rollback.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Razors 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 25
전체 시간: 329
