주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D630은 Latitude 제품군 중 얇고 가벼운 버전입니다. 14.1형 LCD 화면과 9셀 배터리를 탑재하여 휴대성을 강조한 노트북입니다.
I need password system bios
I'm trying to types password is rejecting and I'm trying to
Set up and to boot menu is all rejecting
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I am going to expand on @dinoo_fixit's answer as they missed key details. When you get the master password, it's case sensitive. On the D series and early E series machines you enter it and press Shift+Enter, then it will get you in. The key here is on Core 2 era E series machines it just gets you past the initial prompt - you need to make it permanent as if you were setting a new one. The trick is you need to go into the security menu, put the master password in the administrator password box and leave the other boxes blank - this will clear it out. Once you do that, save the changes and exit the BIOS.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks, this should be the accepted answer
댓글 달기
It is a very old laptop, first of all disconnect/reconnect CMOS battery for an initial reset (Dell Latitude D630 CMOS 배터리 교체) and then use a tool like this (https://bios-pw.org/) to insert serial number/asset tag and get a recovery password
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
BIOS battery hasn't worked since the C6XX series. Master password is the only way.
댓글 달기
답변을 추가하세요
Singo Phumudzo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 328
