주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
표준 하이브리드 파워트레인을 탑재한 6세대 Toyota Camry.
dash cam power connection
what kind of connector does the dash cam use?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Depends on the dash cam - a lot of them rely on the 12V cigarette lighter, but as cars begin to drop it they will rely more on USB-A and USB-C. Some allow you to hardware it into the car, but that comes with a massive implication: F the process up, and you risk a denied warranty claim - DON'T DO IT on a new vehicle. I've just used USB hubs in new vehicles that support it and retain CarPlay/Android Auto over a hub.
The other option is to piggyback off of one of the higher amp fuses (or if you have an option that isn't present on your car but the fusebox has the right amp support), you can use that dormant fuse slot as they use the same fuse boxes across the lineup and just delete unused fuses. VW omits the unused wires, but most do not - check for conductors inside and if you see them, use it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
STEVEN CODRINGTON 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 471
