주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony WH-1000XM3 무선 노이즈 캔슬링 오버이어 헤드폰 수리 및 분해 정보입니다.
Vocal frequence almost gone
Hi, I have these once wonderful headphones, but it seems they now won’t work as before. They seemingly charge, with the light showing red, but the power button really doesn’t evoke them, except very seldom. Sometime also randomly, on its own and then they won’t turn off.
As for the sound quality, the whole middle register, especially vocals, seem to almost vanish into the background. This is regular, even when playing cable only.
I’ve disassembled them according to the given instructions without finding any obvious weak connections. A little rust on the head of two of the long screws was all I could spot.
Any hints? Are they worth repairing, or should I consider recycling them?
-Glenn
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
I think it's worth trying to repair them:
  • regarding the battery I think now they have ~7 years, time for a replacement (it may/should fix the power issues)
  • regarding the audio issues, take a multimeter and check the resistance between start/end point of the cables, it might be due to some cables rupturing internally (they're very thin), if it's very high (or infinity) you got the culprit and got to replace the cable. Also you might try to rework all the solder joints (remove old solder, clean, apply new), especially if some look like "cold joints"
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Glenn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 127
