주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ethernet doesn´t work
I Plug my ethernet cable to laptop and it doesnt show the ethernet icon, so it doesnt work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Hi! What does device manager tells you on the laptop? Any question or exclamation marks? Is the ethernet driver up to date? Did you tried a new re-install?
댓글 달기
답변 1개
=== ***Quick Troubleshooting Steps
이미지
  • Check Ethernet Cable & Port:
    • Test the cable on another device.
    • Inspect laptop port for dust or bent pins.
  • Update/Reinstall Network Drivers:
    • Go to Device Manager → Network Adapters.
    • If you see Realtek Ethernet Controller, right-click → Update Driver.
    • If missing, go to Asus support site and install latest LAN driver for your model.
  • Enable Ethernet Adapter:
    • Control Panel → Network & Sharing → Change Adapter Settings.
    • Right-click Ethernet → Enable (if disabled).
  • Check BIOS Settings:
    • Restart and enter BIOS (usually F2 or DEL).
    • Ensure LAN Controller is enabled.
  • Try Different Port or Router:
    • Rule out router issues by connecting to another port or router.
  • Hardware Fault (if all fails):
    • If Ethernet still doesn’t work, the port might be physically damaged—consider using a USB to Ethernet adapter as a workaround.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gaming Brothers 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 41
전체 시간: 397
