주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5도어 Explorer 및 동급 모델인 Mercury Mountaineer는 2002년형 모델을 위해 완전히 재설계되었으며, 형제 격인 Ford Expedition과 유사한 외관을 갖추게 되었습니다.
Turn signal stops blinking.
When I turn on my turn signal, sometimes it doesn't blink at all. Other times it blinks a few times and stops. The control lever was broken when I got the vehicle and I thought that was the cause but replacing the lever did not fix the blink issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Here are the next troubleshooting steps I recommend
  • Replacing the flasher relay is cheap, easy, and likely the solution to your problem VIDEO GUIDE
  • Checking the signal lamp Frame grounding point
    • There should be a wire that attaches straight to the frame from the headlight assembly. Remove it and sand underneath to remove any rust or corrosion, and replace it.
    • Here are the signal lamps' electrical schematics
이미지
이미지
These are the easy things to check. If this doesn't get you there, I'd recommend consulting a professional auto mechanic.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dan S. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 8
전체 시간: 143
