주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 7D는 APS-C 크롭 센서를 탑재한 Canon 최초의 하이엔드 전문가용 카메라입니다.
card reader needs to be replaced
The card reader will not accept the card, a pin is bent or some sutch
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Replacing the CF pin FPC assembly is a bit involved, since it requires removing the main PCB board to gain access to it (which involves disconnecting a lot of ribbon cables). Fortunately there is a guide available showing how to replace it for the Canon 7D. Note that you may also have to go one step further than the guide shows. The CF card slot has a metal enclosure, but most of the replacement parts you'll find doesn't include this enclosure and only comes with the pin assembly. This means you'll likely have to remove the two screws that are holding the metal enclosure in place so that you can reinstall it on the new part.
Based on a quick search, it seems like a replacement part is going to cost you roughly $50, though you might be able to find someone overseas that you can get it from for cheaper. To aid with searching for a replacement part, the part number is CG2-2544 and the part name is CF Pin FPC Assembly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
victor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 27
전체 시간: 223
