What is the maximum ram upgrade for A1342?
What is the maximum RAM upgrade for MacBook A1342? Is it true that it handles only 4 GB (2x2 GB)?
좋은 질문 입니까?
좋은 질문 입니까?
PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
Details: Supports 1066 MHz PC3-8500 DDR3 SDRAM.
Standard RAM: 2 GB Maximum RAM: 8 GB*
Details: 2 GB of RAM is installed as two 1 GB modules, no slots free.
*Apple officially supports a maximum of 4 GB of RAM, but third-parties have confirmed that it actually supports 8 GB of RAM.
해당 답변은 도움이 되었습니까?
So for an A1342, model identifier 6,1. Processor 2.26, can I do 2x8 gb for a max of 16 gb too??
Sandra your machine maxes out at 8 GB
Do you think upgrading one stick to 4gb and the other 2gb (total 6gb) will work? Mine is running with 4gb (2x2gb) right now. A1342 running 10.12. Thank you.
@abitarroza yes, you can use a 2 & 4 Gb sticks and it will work, just makes sure they are both
RAM Type: PC3-8500 DDR3 Min. RAM Speed: 1066 MHz
According to this site, with the latest EFI update, which is included with App store updates typically (and verified on this mid-2010 MacBook), with Lion or higher it can use 16GB!
http://www.everymac.com/systems/apple/ma...
I will order two 8GB sticks and see, but it makes sense.
해당 답변은 도움이 되었습니까?
Did you ever get around to testing out if the 16gb of ram worked on your A1342? Thanks.
No, for some reason that I can't remember, I went with 8gb.
Hi, 8gb work fine on my mac.
I have buy corsair and crucial and not work..
I buy Kingston and non work perfectly! After install download memtest Open terminal and test it.
Sorry for my bad english
Andrea ITALY
해당 답변은 도움이 되었습니까?
Ciao Andrea! che tipo di Mac possiedi? io ho un macbook a1342 con 2 gb di ram preinstallata. pensi che possa mettere 8 gb di ram? (2X4 GB) Che tipologia e marca mi consigli? scrivimi sulla mia mail gerocoo16@gmail.com.
grazie
seems that at one time for macbook Late 2009 A1342 used 12GB. One 8GB and One 4GB, it ran hot all the time and curdled the rubber under the bottom panel. But it was nice, also had 16GB Macbook A1342, 2010, 7 so they were each comparable, yet….the rubber almost turned into legs underside, it burned out after year.
(What is the maximum ram upgrade for A1342? ) for macbook Late 2009 A1342 used 12GB. One 8GB and One 4GB, it ran hot all the time and curdled the rubber under the bottom panel. But it was nice, also had 16GB Macbook A1342, 2010, 7 so they were each comparable, yet….the rubber almost turned into legs underside
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 15
30일 전: 77
전체 시간: 20,279
댓글 2개
I installed 8gb ram and works just fine and put in 1tb hard drive also working fine
Jason 의
since my last post my macbook 7.1 failed with a dodgy logic board and as it was under warranty i exchanged it for macbook pro 9.2 and i replaced ram with 16gb and its running 1 tb hard drive but saving to replace with 1tb ssd drive
Jason 의
