주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 10월에 출시된 Google Pixel 7 스마트폰의 수리 및 분해 정보입니다. 모델 번호 GVU6C 및 GQML3으로 식별됩니다.
Screen detached from plastic safety frame
The battery was swollen and pushed the screen out, and when opening the phone I didn’t realise that instead of separating the screen with its frame from the chassis I was actually separating the screen from the safety frame.
이미지
The photo above should make it clearer.
Now I imagine the obvious answer would be to get a replacement screen but tbh having already spent 80€ for the battery kit I don’t think it’s worth it (also the screen is fine)
Any chance I can reassemble the screen and frame? What glue could work?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I ended up carefully cleaning frame and screen with isopropyl alcohol, then used a thin layer of T8000, let it dry a few hours before proceeding with reassembling the screen to the device, and finally leaving the phone under a stack of books for 24 hours.
I guess I'll have to report back in some time to see if it holds, but for now the result was quite good. It's most likely not waterproof anymore but I mean, at least it won't blow up anymore.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Giorgio 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 219
