주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1990/EMC 3359. 2019년 5월에 새로운 6코어 및 8코어 프로세서 옵션으로 출시되었습니다.
Why is my trackpad stiff?
I got this MacBook today second hand and the battery is fine, so I'm pretty sure it isn't an issue with bloating. The click registers and works, but even on the firm setting, it feels quite light and not how a proper click should feel. I compared it with another 2019 MacBook Pro, and that one was fine. Is the issue with the trackpad itself? Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The trackpad control logic is on the backside of the trackpad unit. I had to replace one due to tracking issues. The click action is a bit different as the same sensor surface reacts a bit differently as you compress it. I'm sure your trackpad suffered some damage likely a liquid spill that got onto the back side.
Here's the the needed park MacBook Pro 15" Retina (Late 2016-2019) Trackpad and here's the guide MacBook Pro 15" 터치 바 2019 트랙 패드 교체. This is one of the easiest to replace as you don't need to remove the battery.
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar. 이미지
제품
$54.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ryzobyte 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 197
