주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 일본, 2015년 9월 북미에 출시된 Nintendo의 첫 번째 주요 3DS 모델 변경 버전입니다. 2015년형 3DS는 개선된 3D 성능, C-스틱, 새로운 내부 amiibo 지원, 새로운 트리거 버튼 세트를 도입했습니다.
New 3ds lcd issue
Good day ladies and gents
I have a new 3ds of which I have an issue with the lower screen. The device powers on , but only the top screen shows up. The bottom screen is black but the touchscreen works. I have replaced the lcd bottom screen twice but to no avail. The ribbons are secured, the ribbon clip is fine and clean. This applies to the lcd and light connectors. Could I ask if there is anyone that has a solution please
Many thanks
Tobi
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
This question was migrated from https://meta.ifixit.com/Answers.
의
댓글 달기
답변 1개
선택된 해법
Hi Tobi!
Well, then it’s most likely motherboard related. Does the screen shows anything? Maybe the blacklight is just dead. You can check with a flashlight on the screen.
In the worst case, a motherboard replacement is required.
If you can sent any photo, that would help, thanks!
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hi there. I did think it would end up being the lighting issue. I will try and get some photos accoss on here. And thank you for your response 🙂
의
My pleasure! That would help, thank you :)! Then it's most likely something on the motherboard causing this issue. Can be a lot of components. Running tests is required to check for the backlight!
의
댓글 달기
답변을 추가하세요
SplitPancreas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 224
