주요 콘텐츠로 건너뛰기
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
Is my connector lock missing?! How to workaround
Hello!
First time here.
I started to replace the battery on my daughter's 13" MBP A2159 laptop. I got to about the 2nd step - removing the battery daughter board flex cable - and discovered that I either have a different connector (unlikely) or the lock on this one might have broken off when replacing the screen several years ago?
Any advice gratefully received on what to do - how should I get the cable out now? And anything I should do when I connect it again?
Many thanks for the help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@red24631 yes, it sure looks like it is missing. See step 11 on this guide MacBook Pro 13" Two Thunderbolt Ports 2019 배터리 교체
You could try and get a replacement connector and see if you can remove that lock from the new one and lever it into the existing connector. If not, then you would need to replace the connector by de-soldering the old one and re-soldering a new one. If you do not have the tools or the experience to solder that, you will need to have someone else do the soldering for you ;-)
The connector is a FF18-10A-R11AD-B-3H and the Apple part number is 518S00014. they are available at places like this (example only, not an endorsement for the seller)
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks for the info!
For now, I just pushed it in and it seems fairly tight, so we'll see if it stays. Will have to dig deeper if not.
@red24631 awesome! Hope it stays put and will continue to work for you. Repair is War on Entropy
댓글 달기
답변을 추가하세요
Red 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 62
