주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일에 출시된 Apple의 2019년형 가장 크고 비싼 스마트폰으로, 6.5인치 OLED 디스플레이, 트리플 렌즈 카메라 시스템, 크게 개선된 배터리 사용 시간을 특징으로 합니다. iPhone XS Max의 후속 모델입니다.
Face ID is not available
After changing screen and earpiece assembly from IFixIt, the face id is not available. I put the old earpiece in, face ID works (but earpiece is still broke. I have tried two different (NEW-replacement) earpiece assemblies. I still get the Face ID Failure.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This issue is 100% on Apple. They have paired the earpiece speaker assembly to the motherboard using a proprietary encryption algorithm. If the data from the front sensor assembly doesn't match that in the phone, it disables Face ID. No matter how many parts you buy, it will never work unless it is re-paired by Apple, who is the only one that can do it. And of course, it won't work with aftermarket parts, only genuine Apple parts.
In general the only way to get Face ID to work with a new earpiece speaker assembly is to buy a new screen from Apple and pay them to replace it. Their replacement screens come with the earpiece speaker assembly already attached, and as part of the repair process they will pair the new assembly to your phone, reenabling Face ID.
It's not all bad news though. If the problem is only with the speaker itself and nothing else is wrong with the assembly, it is possible to replace just the speaker and keep the rest of the assembly, meaning your Face ID will still work. Since the speaker isn't paired, replacing it doesn't affect your Face ID.
While there isn't an iFixit guide to that repair, I wrote a guide for the iPhone X based on a YouTube video that shows that same repair on your exact phone.
iPhone 11 Pro Max Ear Speaker and battery Replacement Keep Face ID Detailed - YouTube
However, the two phones are similar enough that the iPhone X guide will work for your phone as well. All you have to do is follow the iPhone 11 Pro Max Screen Replacement guide up to Step 26, where you flip over the earpiece speaker.
iPhone 11 Pro Max Screen Replacement - iFixit Repair Guide
Once you're there, skip to Step 29 on the iPhone X Earpiece Speaker Replacement guide and continue on from there.
iPhone X Earpiece Speaker Replacement Without Losing Face ID - iFixit Repair Guide
Doing this requires a very small spot of soldering, but otherwise is actually easier than replacing the earpiece speaker assembly, since you don't have to actually remove it from the screen.
Hope this information helps; let us know how it all turns out for you, as your experience may well help the next person who comes along with the same problem.
iPhone 11 Pro Max 스크린 이미지
안내서
iPhone 11 Pro Max 스크린 교체
난이도:
조정
1 - 2 hours
iPhone X 이어 피스 스피커 이미지
안내서
Face ID를 유지한 채 iPhone X 이어 피스 스피커 교체하기
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Matt Rowland 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 274
