주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Water not being pumped
Very old machine taken out of storage after multiple years of use, water tank has cracked wich I have sealed with super glue and tape. Seems to have either to much limescale in pump or air bubble, can’t suck up any water, I’ve tried to blow on the water dispensary mechanism with a straw with no success wondering what else I can try
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I've had success several times by taking the pump out of the machine (or leave it in and only disconnect pump outlet hose from the downstream component, in Lattissima's case this would be the solenoid valve).
Put pump inlet (hose) into a container of water, or use regular hose connection to the water tank
Then suck (with your mouth) from the outlet side (hose) of the pump. Water will finally move into the pump, enabling it to function again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
michael quinlan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 336
