주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZOYI ZT-703S는 오실로스코프, 신호 발생기, 멀티미터의 기능을 통합하여 다양한 용도로 사용할 수 있는 다기능 도구입니다.
Multimeter function is not working
Hello. I have a ZT-703S with a problem: the oscilloscope function works fine, all buttons work, and it takes measurements normally. However, when I switch to the multimeter function, only a few windows appear, including the analog scale, but no numbers appear. It no longer responds to functions like diode, resistance, and voltage. I updated the firmware and reset the settings to factory settings, but it still hasn't returned to normal. Does anyone know how to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Hi @brunogouve48763
had you checked the internal fuse?
의 공유
Yes, I checked the fuses, they are ok. I haven't found the solution yet.
의 공유
Isn't the issue in below Youtube video a similar issue as what you have?
https://www.youtube.com/watch?v=P6QntvNA...
He was a able to fix it by re-soldering the chip.
의 공유
Hello!
Yes, the same problem as in the video.
However, I resoldered the component as instructed in the video, and it didn't work. When measuring with an oscilloscope, there are frequencies in the transformer's primary and secondary. But it still doesn't work.
의 공유
댓글 달기
답변 1개
Ah OK, sorry to hear it didn't work for you.
Sorry that I can't be of more help.
Hopefully there are others who can.
Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bruno Gouvea de Paula 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 59
전체 시간: 522
