주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 픽셀 휴대전화의 일부인 3a는 구글의 플래그십과 동일한 카메라를 탑재한 실속형 옵션입니다. 클리어 화이트, 저스트 블랙 또는 퍼플 색상으로 제공됩니다. 2019년 5월에 출시되었습니다.
vertical lines after replacing battery
After replacing my battery I had a dozen or so vertical green lines on my display. Fearing I had gotten glue that i had dissolved to get out the old one i took it apart and cleaned contacts. Put it back together and most were gone. But there was still a cluster to the right of the display. After a year this has reduced to a single line that i've learned to ignore. Not the first battery I've replaced but the hardest to get out (this one was previously replaced by a professional), hence the alcohol to loosen the glue. What's your best guess as to what I did wrong?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
There are delicate connections along the edges of the glass the display is printed on that can be easily damaged by the action of opening the phone. Starting with the Pixel 5 they added a frame to the screen that helps mitigate the issue, but on older phones it's a crapshoot as to whether you can get the screen off without damaging those connections.
Even professionals run into this, so don't feel bad if it happened to you. Nothing you can really do except exercise extreme care in taking off the screen on the older Pixels.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
dave presotto 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 127
